Do I Need A CPU Cooler If I Don't Plan To Overclock Right Away?
Jakeola1
5
I'm not planning on overclocking any time soon but i might in the future. Should I just wait and buy one when i overclock?
CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor (Purchased For $198.99)
Motherboard: MSI Z97-GAMING 5 ATX LGA1150 Motherboard (Purchased For $135.36)
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory ($60.25 @ Amazon)
Storage: Samsung 850 Pro Series 256GB 2.5" Solid State Drive (Purchased For $119.99)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($52.49 @ OutletPC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card ($339.99 @ SuperBiiz)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case ($69.99)
Power Supply: EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply ($64.99 @ Amazon)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) ($86.95 @ OutletPC)
Monitor: Asus VS239H-P 23.0" Monitor ($150.99 @ Amazon)
Keyboard: Logitech MK120 Wired Slim Keyboard w/Optical Mouse ($14.89 @ SuperBiiz)
Total: $1294.88
Generated by PCPartPicker 2015-05-16 23:08 EDT-0400
so it should be fine if i plan to overclock sometime in the future perhaps?
You'll need to buy a better cooler to overclock it, but the stock cooler is fine at 3.5 GHz. Just don't run Prime95 28.8 for several hours as it will most likely get to 100°C and throttle.
The stock cooker, when installed properly in a decently ventilated case, is more than adequate for stock clocks and voltage at liveable temperatures. My i5-3470 only reaches 75C when my room temperature hits 40C in my Antec 300-2 case with the two front intakes on medium speed and the rear exhaust on low speed. Unused fan locations (top and sides) are taped shut.
An i5-3470 is much easier to cool than an i5-4670K and it can't get as hot running Prime95 28.5 Small FFTs since it lacks the new instructions that can make the CPU run really hot. Your i5-3470 most likely gets hotter than 70°C running Prime95 Small FFTs for at least 15 minutes. My room temperature is 23°C and my i7-3770 with the stock cooler gets warmer than that (84°C according to Intel XTU).
People do not normally buy CPUs to run Prime95 and my 75C was with the CPU at ~80% load 24/7 running a broad assortment of stuff.
