R rcfan12 Reputable Nov 24, 2014 45 0 4,530 Dec 20, 2014 #1 Is it a necessity or can i do without one ?
Solution boju Dec 20, 2014 Without a cooler the cpu will fry in seconds If no overclocking and ambient temperatures are not extreme then stock cooler is fine
boju Titan Ambassador Jul 7, 2008 21,621 2,504 88,390 Dec 20, 2014 Solution #2 Without a cooler the cpu will fry in seconds If no overclocking and ambient temperatures are not extreme then stock cooler is fine Upvote 0 Downvote Solution
R rcfan12 Reputable Nov 24, 2014 45 0 4,530 Dec 20, 2014 #3 so i would need to add a cpu cooler to this build ? Or does the cpu come with one ? http://pcpartpicker.com/p/6yP6P6 Upvote 0 Downvote
boju Titan Ambassador Jul 7, 2008 21,621 2,504 88,390 Dec 20, 2014 #4 Yea it includes it, it says it down the page if you click the cpu. Upvote 0 Downvote
boju Titan Ambassador Jul 7, 2008 21,621 2,504 88,390 Dec 20, 2014 #5 The heatsink will have already applied paste on the heatsink under surface with a peal off tab. Upvote 0 Downvote
R rcfan12 Reputable Nov 24, 2014 45 0 4,530 Dec 20, 2014 #6 Ok thanks alot for the help! Upvote 0 Downvote
