Do I need a power supply?
Shashank Gupta
I am building a desktop with the following config:
Intel i5 4430
ASUS H87 Pro Motherboard
Corsair Vengeance (1 * 8GB) RAM
Basically, I am a stock trader and want a desktop to set up 4 monitors simultaneously. I am not sure whether I would need a separate graphic card so have ordered the items listed above for now.
Would request if anyone can help me understand whether I would need a separate power supply unit?
Yes 500w is more than enough since you want to buy a dedicate GPU.
Don't forget to select the best solution if it helped you. will help others with same problem.
You need one Power supply unit for your desktop. If you want to set up 4 monitors then you need as many ports in the first place. you will not need a seperate PSU as monitor's power cables are plugged separately
