Do I need hose clamps for barbed fittings?
Ethanh100
I am building a watercooling loop and planning on using barbed fittings because they are much cheaper. Do i need hose clamps o every single fitting? Will i be pretty safe without them or is it too big of a risk? Thanks!
yeah that was the one thing i really didnt know because i was planning on using compression fittings at first. Thanks though.
i would also suggest this. the kits are all the same parts you would normally buy seperately, but often at quite a lower price than buying piecemeal. they also come with all the things you need to build a simple loop, usually including either compression fittings, or clamps with barb fittings.
as for clamps alone, yes. use them. i've seen people say they never used them and never had a problem, but how much will some clamps cost? compared to replacing a soaked gpu or worse? better safe than sorry.
