If you have an actual RAID setup the Management software that boot up just tells you if the RAID is Ok, If there are warnings, Or failures. BUT if you don't have any RAID then there is no point of having the software startup with the PC. This has nothing to do with the SSD. If you have Two SSD's in a RAID 0 or 1 i would say leave it but you don't. So just click on Start, type in MSCONFIG in the search box, then go to the Startup Tab and then uncheck the Intel Stuff. and then ok and restart.
