I was playing shadow of mordor at 900p and I am noticing a lot of jagged edges. My monitor is only 19" and I have also turned on FXAA inside the game. So I don't think I should be seeing jagged edges.
I checked the nvidia control panel and it shows the following settings-
Antialiasing- FXAA = Off
Antialiasing- Gamma correction = On
Antialiasing- mode = Application controlled.
SO my question is- If the antialiasing mode is set to "application control" then will it override the fxaa setting too according to the in game settings? Is it normal to see jagged edges at 900p with fxaa or is it happening because it is "off" in the control panel?
