In particular, this case - https://www.amazon.co.uk/Game-Max-M...ening+case&qid=1574098668&s=computers&sr=1-15
i never said the be quiet fans are bad
be quiet cases with sound dampening are not ideal for parts that work hot, because the design of the case and the speed of the fans are focused on reduce noise, at the expense of temperature, not much more, but extra when compared to a meshify c case or similar high airflow cases
the fan is a fan that spins, moves air and does it silently, nothing wrong with it, at all
any fan can be replaced, but the rgb is the problem, if it uses a specific controller integrated in the front or top of the case, the new fan will not work with it, so you loose rgb control but if you say you don't care, well, buy the best noctua fans or the best be quiet fans you can, a fan hub to connect all fans in the hub and control it with the motherboard fan header and set the fan curve on that header to low speed
if that is not enough, then you can consider a new psu and new case, but first try the fans, so you don't end with a case that has no use for you that makes you feel like you wasted time and money
often the stock fans on cases are just bad, it has been my experience with corsair and nzxt, so i end up changing them always for new ones
i was checking the pure base 500, it seems as a low airflow case, it only has some small ventiallation grills on the sides in the front, very few reviews of itI think I have found some good fans.
https://www.amazon.co.uk/Noctua-NF-...NF-S12A+pwm&qid=1574283978&s=computers&sr=1-3
- Do these come in 140mm?
- Would they pair well with Pure Base 500 case?
- Do I buy 3-4 and take out my pure wings 2 that come with the case, or just another two to go with my Pure wings 2?
