Seem a rhetoric question.
The problem is we can't know exactly.
Your motherboard/cpu could take 50 watts to 150 watts.
corsair h80i should be around 10-20watts.
hd is around 5-10watts.
fx9590 is up to 220 watts.
gtx 760 is around 160 watts. (x2)
This give us roughtly 720 watts.
And to be fair, your unknow psu could not deliever 100% efficiency so on 740W.
This give us a PSU loaded at 97% on high load...
At my opinion, you are borderline.
The problem is you're in the grey zone.
Could work fine for years or just reset in your first demanding game.
2 options:
1. you can try it and be sure that your next buy on this PC is a psu.
2. Try a Watt meter (Kill a Watt, UPS,...) to know how much you use in a demanding game (high load). If you are under 480 Watts, you can give a try (thinking it's should work).
