Do PS4's require dust cleaning
Aaron Singh
35
Are they designed to be dustproof or do they need constant cleaning. I do not really want to open my Ps4 up, as it will void my warranaty, and I dont want to vaccum it, since it creates static. If my PS4 had lots of dust in it, could it affect peformance, e.g frame drops.
Some games just naturally have frame drops because of the limitations of the console hardware. I've owned my PS4 since launch and haven't had to dust anything internally. You could try using a air canister on the vents, but the PS4 vents air out, and doesn't take much in, so you shouldn't have to dust it much, just keep the exterior clean and you really should be fine.
