I wonder if USB NFC readers work with Yubikey, such as this one:
KKmoon NFC ACR122U RFID Contactless Smart Reader & Writer/USB + SDK + IC Card
I'd like to be able to do the 2 factor authentication with Yubikey without having to plug it to USB, just by putting it close to the USB-attached NFC reader on a PC...if that's possible.Your link is to a contactless card scanner that plugs into a USB port.
YubiKey is a different product.
Are you able to provide more information about what you wish to do, the requirements, and the working environment?
You must pay close attention to the standards being used by the reader and the card.
The following link should prove helpful:
https://support.yubico.com/hc/en-us/articles/360013707820-YubiKey-Smart-Card-Deployment-Guide
Hi Ralston18, Thanks for your answer.No.
That said I am not sure that I understand your 2FA question.....
Hardware will not work if not connected.
And if connected said hardware will not work without the applicable software drivers and configuration settings on the host computer.
What are you trying to do?
However, reading back, I may be misunderstanding what you mean by Yubikey and its' application.
My understanding and expectation would be that if you have a physical Yubikey then you plug it into the host computer which then detects the physical device and likely prompts for some accompanying PIN to confirm your identify and authorization to use the computer.
Waving the a USB Yubikey over some sensor pad is not going to work. Caveat being that if the Yubikey is also some sort of card then you will still need to provide a PIN.
More information needed.
