Does 64bit use more cpu then 32bit
blue90
107
I will be running multi applications (rs bots), right now I am bitting my max ram which is 4gb on my 32bit. I have 8gb's installed tho. So my question is now, if i run these bots will it use more cpu if I run it on 64bit? Im at 40%cpu usage on my 32bit...
It will be smoother, but some apps wont work properly on the 64 bits versions.
And normally on Win7, ram usage is always high due to shared resources or video card driver memb but it should not affect your processes as you'll be on full 8gb max!
Oh ok, so the cpu wont be affected at all. I am wondering about this because i know the 64 bit takes advantage of the 8gbs, but I dont know if it uses more cpu then others.
