Does a coolermaster 212 hyper evo fit in a Zalman ZM-T4 case?
It might fit looking at the physical specs but on the Zalman site there's no note of CPU clearance. That being said though the stock cooler that comes with the 2600 is quite good, I would try overclocking with the stock cooler first and see how well you do. If you don't get good results then consider a aftermarket solution and you'll be able to measure the space and see which cooler you can go with.
