Specifications
mATX, Mini ITX, DTX motherboard compatibility
Drive bay capacity: 2 - 3.5" HDD or 3 - 2.5" SSD or 1 - 3.5" HDD + 1 - 2.5" SSD
2 - ODD slots
1 - FDD slot, using convertor in ODD slot (convertor included)
4 expansion slots with sleek white painted brackets
Supports graphic card up to 350mm in length with one HDD mounted
Supports graphic card up to 210mm in length with two/three HDD mounted
Supports CPU coolers up to148mm in height
Supports full size ATX PSU, maximum length about 185 mm if an optical drive is mounted
Case dimensions (WxHxD): 175 x 355 x 420mm
Net weight: 4.1 kg
Package dimensions (WxHxD): 225 x 415 x 475mm
Package weight: 5 kg
fractal.com
