Does a Fractal Celsius C24 fit with a Strix 1060 in the Define C case.
Wabaoxr
14
I plan on buying a Fractal Design Celsius S24 and I was wondering if it would fit in the front position of a Define C. I have a Strix 1060, but I know the Strix Nvidia 1000 series are all the same length.
If it doesn't fit in the front, would it fit on top? I have a Strix Z270e.
From Fractal.
Water cooling compatibility - Radiators
Front – 360, 280, 240, 140 and 120 mm. Max width 144 mm
Top – 240 and 120 mm radiators. Max component height on motherboard 40mm
Rear – 120 mm. Max width 125 mm
means no ram higher than 40mm when reading this.And probably vrm cooling but don't think they will be that high.
From Fractal.
