Does a Powersupply Heat up?
  • Thread starter Thread starter Guest
  • Start date Start date
G
Guest
Guest
I am now running a second powersupply that is running all my extra case fans, and since the powersupply itself has a built in fan, it sort of makes sense to put it in the case to push some air around, but i am wondering if anyone would object to this idea, I have had it running with just the fans hooked to it and the power supply is still cold to the touch, so i cant see it adding to the case temperature, but thought i would pass it by the general community here and see your thoughts on the subject. is there any reason not to put this second ps in the case.???
oh and just a side note, Wacom tablets rock, I am using a 9x12 intuos for my graphics work,
yes, your powersupply will heat up. The right cooling will keep it cool.
Cel 533 - 256mb sdram
15gb HD - ati radeon 32mb ddr (200/200)
SB live! mp3+ - win98 Beos
Yes, but not so much that you would notice, if the fan were to stop, you would certianly notice then
The inventor of Sick Puppy
Ok, what I should say is that if your extra power supply is blowing it's fan out the back of the case it REMOVES more heat than it adds. That is, it evacutes air from inside the case faster than it can heat it.
Suicide is painless...........
