Question does a psu wattage account for transient load spikes, & will a 650 be enough for this build?
May 6, 2023
12
Intel Core i7-14700K 3.4 GHz 20-Core Processor15W - 253W
Deepcool AG620 BK ARGB 67.88 CFM CPU Cooler5W - 10W
Asus ROG STRIX B760-I GAMING WIFI Mini ITX LGA1700 Motherboard7W - 30W
Patriot Viper Venom RGB 32 GB (2 x 16 GB) DDR5-6200 CL40 Memory29W
Western Digital Caviar Blue 1 TB 3.5" 7200 RPM Internal Hard Drive4W - 20W
Western Digital Blue 2 TB 3.5" 5400 RPM Internal Hard Drive3W - 15W
Western Digital Blue 4 TB 3.5" 5400 RPM Internal Hard Drive3W - 15W
Samsung 990 Pro 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive2W - 10W
GALAX (1-click OC) GeForce RTX 3060 12GB 12 GB Video Card42W - 170W
Cooler Master SickleFlow 62 CFM 120 mm Fan1W - 5W
Total:582W
this is my current part list, is an A tier 650 gold rated power supply?
people on reddit are making me doubt that it'd be enough, saying to get at least a 70 or a 850, is it really safe to run this close to the wattage?
Which "650" PSU, specifically?
Yes it's 'safe' - maybe not the most efficient, but 'safe'. UNLESS you play on frequently (not rarely) running every component at 100% power-draw, you won't even come close to the ~582W listed.
Assuming you're not overclocking the snot out of the 14700K, of course - but the AG620 ensures that's not happening.
EVGA SuperNOVA 650 G2, 80+ GOLD 650W
Reactions: Barty1884
Your PSU will do just fine, if you worry about the quality of the energy that goes into your power supply, i would suggest a UPS.
May i ask what all those HDD's are for? Just curious:)
just old ones from my dead pc, it had a X99A-MPOWER, which had 10 SATA ports, so whenever I ran out of space, I would buy a new one, but the new mb can only take 4 sadly xD
Sounds like a good reason (if you really need all the stuff on them) to setup a separate system as a file server. Can be done for very little cost and allows your new rig to be free from all the clutter.
