Hi,
Unfortunately, I made the mistake of mixing RAM series for a 32GB to 64GB upgrade to my workstation. Original RAM was two Kingston ValueRAM 2400MHz 16GB DIMM's. I added two Kingston HYPERX 2400MHz 16GB DIMM's in the hope that the same vendor should be compatible.
Despite this hope with the new RAM the PC is stuttering all over the place is literally unusable. Now I have two questions.
First: Does anybody know what is causing the stuttering from a technical perspective?
Second: Does RAM has to be not only the same vendor but also the same series? And in a series does it have to be the exact same spec as compared to for example having a 2666MHz stick in a 2400MHz system?
Thanks
Thanks
