I've been running into booting issues and I'd like to explain whats happening and ask for help.
For Christmas I got a new motherboard and CPU as well as a coolermaster CPU cooler. It was a gigabyte x570 gamingx and a Ryzen 7 3700x. I wanted to control the rgb on my new cooler so I downloaded 2 softwares, Aura Sync and tried but failed to download rgb fusion. So I went for MSI's light sync. It asked me to reset once I installed and so I did. Here's where my issues started. It reset and boot me straight into bios. I had to reinstall Windows and so I tried the rgb stuff again. This time going in a different order and the same stuff happened after like 3 downloads. So I stopped and reinstalled again. This time not downloading any softwares. I set up everything again, updates, softwares, games, etc. Reset for updates and drivers and it was fine. Booted up fine. I'll go with six or seven hours of usage I shut down and go do something. I come back, turn on my PC, and straight to bios. After this I got a new HDD and an external HDD to backup and see if a different drive would fix it(It didn't). I've tried installing countless times to see if that would work and it didn't. I went and installed a newer version of Windows installer on my flash drive and tried that. Still didn't work. I found a way to use my rgb with rgb fusion so that was a plus. I've tried using a different motherboard and see if it would boot with that. Nothing. One still of RAM. Nothing. Without my HDD and just my SSD(my boot drive) nothing. Now here's what happened on my attempt today. I setup with my regular stuff and wiped my HDD with all my games on it. I was reinstalling over night and had windows updates pending. I shut it down this morning and went to school. Came home and updates finished and I started installing again. I installed my browser again and downloaded Origin launcher again. Once it installed I had to allow it's access or whatever it is and once I did that, moments later my PC ran into a problem, had to reset, and didn't boot. I'd like to say that I have a KMS38 HWID key activated and I don't know if that's the issue but I also don't know how to deactivate it to test.
So I'd like to ask for help on a few things. 1: how do I fix this or what can I do to fix it? 2: If it is the HWID key how do I deactivate it? 3: How can I make my rgb cooler be found? I tried the cooler master software but it couldn't find it either. This PC was my hobby and I've been stressed and frustrated with it for weeks. I don't know what else to do.
