G Gamer_X Honorable Dec 1, 2016 57 0 10,540 Jun 25, 2017 #1 hey guys whats the difference between a 51 whr battery and 96 whr battery does the increase in whr just mean longer battery life or will there be an significant increase in the performance in the gpu or cpu as the whr increase?? plzz help thanks
Solution S S sizzling Jun 25, 2017 Their is zero impact on performance. The laptop will draw the same voltage and Amps, its just drawing from a bigger tank which takes longer to empty.
S sizzling Titan Oct 18, 2006 27,218 3,268 112,240 Jun 25, 2017 #2 Just increases battery life. Think of it like a bigger fuel tank in your car, its still the same fuel just more of it. Upvote 0 Downvote
G Gamer_X Honorable Dec 1, 2016 57 0 10,540 Jun 25, 2017 #3 so theirs no increase in performance and the gpu and cpu will be able to perform to their maximum on any whr battery ?? Upvote 0 Downvote
S sizzling Titan Oct 18, 2006 27,218 3,268 112,240 Jun 25, 2017 Solution #4 Their is zero impact on performance. The laptop will draw the same voltage and Amps, its just drawing from a bigger tank which takes longer to empty. Upvote 0 Downvote Solution
