W wewum Reputable Aug 30, 2014 422 0 4,810 Nov 8, 2014 #1 I used BurnInTest to test my PC's temperature. I averaged about 50 degrees celsius with a max of 60 when I was checking my email. Is BurnInTest testing under load or when idle?
Solution kanewolf Nov 8, 2014 It will be under load. You should be able to bring up Windows Task Manager and see all the CPUs at 100%
kanewolf Titan Moderator May 29, 2013 37,487 3,335 156,790 Nov 8, 2014 Solution #2 It will be under load. You should be able to bring up Windows Task Manager and see all the CPUs at 100% Upvote 0 Downvote Solution
