[SOLVED] Does components fit in NZXT H500
Dec 28, 2018
35
Hi i have a few questions. First of all i spend around 1-2months of watching videos about PC Building and stuff and i started choosing the components but im not still sure if i choose the right one and if they fit without any problems because it will be my first build. I also check components with PCPartPicker but some people says that sometimes is not right.Also i found PSU on Slovak website (yes im from Slovakia) on PCPartPicker wasn't there. Anyway if someone have time to check it out i will be happy and glad
Links:https://pcpartpicker.com/list/c6s8Bb
Individual link to PSU:https://www.alza.sk/evolveo-g550-cierny-d4562826.htm
Yes they should fit but some of your components could be replaced with better ones in the same price range. Ex I would go for a ryzen processer in your price range specifically the 2600x for $10 more than the 8400 it outperforms it (also comes with a decent cpu cooler so if you don’t want to you don’t have to buy one).for the gpu I would go with an rx580 over the 1050 4gb .
Reactions: pacikjean
