does Corsair CX750 80 plus gold power supply have 8 pin and 6 pin outputs?
HB35G
29
im considering getting a Corsair CX750 power supply to run my gtx 480 in my computer, the card needs 1 6 pin and 1 8 pin connector. i need to know if it has those outputs before buying it. THANKS!
That's a bid price , its likely to go much higher.
There's a 650w model here which is $75 BIN with a best offer option.
https://m.ebay.com/itm/EVGA-SuperNOVA-650-G2-80-GOLD-650W-Fully-Modular-EVGA-ECO-Mode/122742279306?hash=item1c94028c8a%3Ag%3AEV4AAOSwV4BZ2Aya&_trkparms=pageci%253A2936e30f-bc83-11e7-9c6b-74dbd180a1c4%257Cparentrq%253A673f395515f0a9cb9fe2588bfffbbf73%257Ciid%253A14
A psu is the one PC component I would never consider buying second hand unless it was from a friend & I knew it's complete usage history
The title says CX750 80 plus gold, but there is no CX gold rated unit from Corsair. Either way, if it is 750W from Corsair it does have enough power connectors for your RX 480.
Are you referring to the Bronze rated CX750? If you are I recommend the new (2017) grey-label instead of the older green-label.
im gonna get the green label model because its more affordable and also its a geforce gtx 480 not a radeon rx480.
Do not, absolutely do not buy a green label model. I'm warning you now, that PSU is incredibly low quality and you should not be using that PSU for anything but office-grade PCs and VERY low use scenarios.
Gray label CXMs are significantly better quality.
EDIT: A GTX 480 is far more than enough to push it to a limit you want a green label CX to hit. If it were me, I would spend the extra $20-40 and get a PSU that doesn't have the same level of potential to damage my components.
what about a evga supernova 750 watt?
The old & new cx750s are virtually the same PSU, the 750 never had anything in common with the rest of the range as it's always been a dc-dc regulated unit.
That said you should go for the new silver labelled cx650/650m over either of the 750s.
More than enough power & absolutely better quality
The supernova g1's should be avoided if possible.
https://www.ebay.com/itm/Corsair-CX-Series-750-Watt-80-Plus-Bronze-Certified-Non-Modular-Power-Supply/253228461116?hash=item3af597ac3c:g:Ce8AAOSwoVNZ8p0F this is the corsair i was looking at, other wise im getting this https://www.ebay.com/itm/EVGA-SuperNOVA-750-G2-80-GOLD-750W-Fully-Modular-EVGA-ECO-Mode/142547633900?hash=item21308046ec:g:XwEAAOSw~RVZ7AOw
