I want to tape an extra hdd since i have used all 4 slots and also want to tidy up the cables using thr electricical tape. I assume it doesnt cause static since its for electricians and feels like rubber. Any help? Thanks in advanced!
nice one .. I would of thought cheap vinal [black] tape could ?? I guess you got to look at whats covered and how well made the tape is like known name brand over cheap no brand china made ??
I looked at this and did not come upo with anything quick but this maybe as a guide ??
[under tape performance ]
''Anti-static/ESD Control - Anti-static tapes or ESD control tapes consist of conductive, foil or metallized backings and are used in applications requiring control static charges or electrostatic dissipation (ESD).''
maybe contact a company like 3M or a known name brand to see what they say on there tapes ??
I feel that for cable management just to bundle up cables all should be ok to use ?? small zip ties or Velcro straps [what I now use] should work as well
I think if you could use a zip tie or 2 to mount the hdd may be a better deal overall there cheap
