Does Geforce GTX 760 fit Gigabyte f2a58m-hd2 motherboard?
Eefay
28
I actually bought wrong graphic card,now i want to change to GTX760 but i scare my motherboard dont support GTX760.....
HELP ME GUYS T_T
Your motherboard has a PCI-e x16 rev.3.0 slot and that is the latest. Most GTX 760's (if not all) will have a PCI-e connector. Most will require two 6-pin power connectors from your PSU so you will have to check that. They are dual slot GPU's so you will have to determine if you have two open slots at the back of the case. And some of these cards can be quite long so you need to be sure that the length of the card fits in your case.
Best thing to do is to use PCPartPicker to enter your components into and it is very good at picking of incompatibilities. Here's an example of a build with incompatibilities. Just click on the link to see.
PCPartPicker part list: https://pcpartpicker.com/list/ZT4kZ8
Price breakdown by merchant: https://pcpartpicker.com/list/ZT4kZ8/by_merchant/
CPU: AMD - Athlon X4 860K 3.7GHz Quad-Core Processor ($49.99 @ Amazon)
Motherboard: ASRock - FM2A68M-HD+ Micro ATX FM2+ Motherboard ($44.99 @ Amazon)
Memory: Kingston - 8GB (2 x 4GB) DDR3-1600 Memory ($44.69 @ Amazon)
Storage: Seagate - BarraCuda 1TB 3.5" 7200RPM Internal Hard Drive ($42.49 @ Amazon)
Video Card: Gigabyte - GeForce GTX 760 2GB WINDFORCE Video Card
Case: Cougar - MX200 ATX Mid Tower Case ($32.99 @ SuperBiiz)
Power Supply: EVGA - 430W 80+ Certified ATX Power Supply ($29.99 @ Amazon)
Total: $245.14
Generated by PCPartPicker 2017-06-30 08:07 EDT-0400
Shit, My power supply connect is 4pin-fdd,doesnt match with the graphic card ,,so what should i do now ?
Should i buy a molex adapter ?
do i need this adapter ?
4-Pin Molex IDE to 6 Pin PCI-E Graphic Card Power Connector Cable Adapter
MERGED QUESTION
Question from Eefay : "Power Supply Connector doesnt match with my grapghic card"
MERGED QUESTION
Question from Eefay : "Will one 4pin Molex to 6pin PCI-E adapter power a GTX 760 ?"
Should i buy 2x4pin to 6pin or one 4pin to 6pin?
