Does i5 work on MCP61P-NARRA3-00
mihaita123
17
Motherboard ID 10/09/2008-MCP61P-NARRA3-00, Motherboard Name Asus M2N68-LA (Narra3)
Does a intel core i5 processor work on this motherboard?
The x4 9600 is better than your x3 8600, but the gains are not worth the money you throw on it (between 0% and 10% gain, mostly in CPU-intensive games/programs because of the additional core, the frequency being the same, 2.3GHz).
What you can do: buy a motherboard with DDR2 + DDR3 support (http://www.pcgarage.ro/placi-de-baza/asrock/960gc-gs-fx/) and use the x3 and DDR2; when you will afford buy a second-hand Phenom x4 945 (3GHz, 95W TDP) which can work with your actual DDR2 memory; after a while you can buy a 2x2GB or 2x4GB DDR3 kit and sell the (x3 + M2N68 + DDR2) as a kit.
If you can wait a little longer, the best is to go with an entirely new platform, FX-6xxx/FX8xxx (DDR3, Socket AM3+, high power consumption, end of life) or i3/i5 (DDR3, Socket 1150, high efficiency, still acceptable upgrade path).
pot astepta i can wait
Do you already have a budget? Take a look here:
http://www.pcgarage.ro/vizualizare-wishlist/986037/
You will need to add the case, a HDD + a DVD (both SATA); for max. 1366x768 (and low image quality), the onboard HD 4400 will do for light gaming. You could add later a graphics card (max. GeForce 750 Ti or Radeon R7-260x) and you'll end up with a decent gaming system (enough for Full HD resolution, 1920x1080, and medium image quality).
If you already have a graphics card, you can also go with an AMD system:
http://www.pcgarage.ro/vizualizare-wishlist/986055/ ; this motherboard has the advantage of an IDE (PATA) port, which can be handy if you still have an IDE HDD/DVD.
