Does Intel Heat-sink and Fan LGA 1155 fit the HP 8300 SFF Motherboard with socker LGA 1155, as I'm struggling to get the intel Heatsink to fit on the Motherboard
From your HP 8300 SFF MB layout, it is the BTX format MB, you can't use the regular lga1150 atx format cooler on that BTX MB.
Here is the BTX format MB looks like. http://www.hardwaresecrets.com/btx-motherboards/
It is definitely an ATX board in terms of layout and fitting perfectly into an ATX case. It is just the heatink mounting holes that are oddly different
