[SOLVED] does it worth buying 120HZ refresh rate monitor on GTX 1060?
whiteknights
777
I'm Going to Buy GTX 1060, and i was thinking of getting 120HZ refesh rate monitor so i can make use of the extra 60+ FPS (if there will be any extra FSP?). modern games like from 2015 till now.
does it really worth it buying 120HZ monitor instead of my currnt 60HZ monitor.. or i won't be getting above 60 FPS at most games with GTX 1060?
high refresh monitors are always worth it. Depending on the game, resolution and video settings you might very well reach high frame rates. Especially when you are playing in 1080p.
