Does light show through the Meshify C's front?
Superrex99
Commendable
Feb 8, 2017
I've been looking at the Meshify C as an option for my PC case and I need to ask, does light show through the mesh front?
I want to add 3 RGB case fans to the front side but if it doesn't show that well I might as well go for non-RGB fans and save some money. Thanks for the help.
It's see through. I've seen several review videos on it and while they didn't use rgb fans, when they tilt the camera once the setup is done, you can see through the mesh front and fans all the way into the case, and see the mobo and video card light up so you should have no problem seeing rgb fans, they shine pretty brightly and are right at the front.
