oh ok but a cpu with ddr4 2666 will be fine with using ddr4 3200It depends on the supported speed of the motherboard.
Yes, but it comes down to the motherboard. For example if the max speed on the motherboard is 2800mhz then the 3200mhz memory will be downclocked to that speed. Initially the speed may show up as 2133 but once you enable XMP it should run at the correct speed or the max the motherboard will support.oh ok but a cpu with ddr4 2666 will be fine with using ddr4 3200
No problem! If your getting a motherboard that's not a Z390 make sure the BIOS is up to date to accept that 9400F or else it won't boot.okie dokie thank you so much for your insight.
Yes, 100% sure.see with your cpu it says its memory time is ddr4 whereas mine says ddr4 2666 so are you sure it will work with ddr4 3200 provided that the motherboard allows it
No problem at all, we were all new to this at some point.ok i get it now, sorry for my incompatance.
Links are ok but if you can list them PCPartpicker that would be better.hey can i send you a bunch of links to the parts I've picked and ask if they will all work together, totally ok if you don't want to.
Of course, we enjoy helping others!thanks for all the help by the way, it is much appreciated
