Under heavy load, I noticed that the GPU seems to adjust power draw in order to keep the temperature around 80C.
When sitting on a desk, with no obstruction to cooling, I found that the GPU draws around 130W (fluctuates between 125W and 136W). When sitting on my lap, so the cooling intake vents on the bottom are partially obstructed, the temperature remains the same, but the power draw eventually throttles down to around 80W.
This got me wondering, as better paste is reported to improve cooling by as much as 15C, would this improvement in cooling significantly boost performance by allowing the GPU to draw more power while still remaining around 80C?
Game used for testing is AC Valhalla set to Max Settings @ 4K.
Windows is set to Max Performance, NVIDIA Control Panel options are set for Max Performance. GeForce Whisper Mode and Battery Boost are turned off and BIOS settings are set to Max Performance.
