Hey,
If you look at the inside of the case, you will see that cards longer than the motherboard will not fit. But doesn't mean that some 7870/7850 will not fit. I have three 7870's at home, one is a sapphire hd 7870 OC dual X, its maybe something like 23 cm long, so no problem, my gigabyte windforce 3 version will not fit I think cause it is like 27cm long, and my HIS IceQ X Turbo will be just to long I suppose (24-25cm?) Everything below 23 cm will do the trick. So to find a 6970 smaller than 23cm will be difficult to find, would't exist i think. And every 7770 will fit for sure. I have a sapphire 7770 Ghz to and its small, like 18cm and fast, turns BF3 in Ultra on 1080P online with nice frames, so do my 6850 cyclone power edition(best card ever made) 😉
