Does Sapphire VGA R7 250 1GB supports DirectX 11
good because i might take that gpu. And something else can i play wolfenstein the new order whit this gpu intel core 2 quad q9300 and 8gb ram? if yes how many fps in low medium and high?
For 15 euro more you can get r7 360 from the same site. You will need 6 pin power connector and 500W psu according to sapphire.
I think you will be able to play it. On what resolution you will play?
