I know the more cuda cores in a GPU the better is the performance but will a difference of 128 cuda cores makes any significant performance difference?
Gtx 1050 ti has 768 cuda cores and 1050 has 640 cuda cores. So, there is a difference of of 128 cuda cores. If I choose one GPU between 1050 ti and 1050 which one should I choose?
My specs are:--
Windows 7
Pentium G2030 3.00 GHz
6 GB RAM
GIGABYTE H61M-S
Zebronic 450watt PSU
I know its an old and weak PC but I want a GPU for it.
So, small difference in CUDA cores in a GPU makes any difference in performance?
My specs are:--
Windows 7
6 GB RAM
GIGABYTE H61M-S
