so i do understand that the sp fans make high pressure but move less air and the af fans make low pressure but move much more air, but this is on the outlet, what about the inlet? Ive got a case side door with the dust filter, THEN the fan, then a lot of open space inside the case(no grill after a fan, no cages, nothing). So no need for pressure inside. The thing that confuses me is that i dunno if the pressure fans make the air come through the dust filter BEHIND them with the same strong force that appears then infront of them (thus helping the air to come through the dustfilter behind) or they dont work backwards? Because if they dont, the af fan would be much better cus it would move more air through the filter at the same rpm. Wonder if theres any aerodynamics guy that can explain it. Thanks a lot
