I'm using a Cooler Master Cosmos 1000 and it has a 6 pin on the front. Is there a spot where the wires are supposed to attach to? Is there a wire for it? I think there was supposed to be a plug like 1394 or something like that.
No Firewire connector available on board. Do you need Firewire for a camera or other device?
Not sure myself, I have a video camera. I might need a driver for the camera. Since you said there isn't a way to connect the firewire to the motherboard.
I've never used one. According to the reviews, it should work.
Thanks for the assistance, but sadly the reviews said it doesn't. Or something isn't wired right. What I did next is get a Rosewill PCIe Firewire 1394a Card. Plugged it into the motherboard and it works flawlessly.
