Does this pc build need more fans?
williams524
4
Hi,
I have a CoolerMaster CM Force 500 PC case with a i7-7700 CPU and a Gigabyte B250 motherboard (GA-B250M-DS3H)
The power supply is CoolerMaster 500W B500, and I have LG Sata DVD drive.
the cpu fan is: CPU - ALPINE 11 REV2 ARCTIC
graphics card: gtx 1060 Gigabyte xtreme - 6gb
and 16 GB RAM (kingston hyperx fury, 2400 mhz)
I have one ssd SAMSUNG 850 evo (250GB) and one 1TB Western Digital blue hard drive.
The case come with one pre installed fan (Rear Exhaust)
Is this build good?
Do I need to install more fans on this system or is it suffient to cool it?
Depends on your location, And I don't think you will be needing any more fans, If CPU is in Air Conditioned Area, not in some Wooden Cabinet barely capable of air circulation. Although it will work fine for first 2 years given that you are cleaning it every month with blower( Don't remover Fan from Processor While cleaning it, Just use high pressure Blower.)
