[SOLVED] Does this PCIE Extender (Thermaltake Gaming PCI-E 3.0 X16 Riser Cable) Provide power to a 1650 low profile?
Frankie4Fingarz
Commendable
Apr 24, 2019
81
7
1,545
Hey just need to know as my 1650 doesnt fit in the pcie slot so I need a riser to provide a slot but now im concerned the card wont be powered. here is the Riser
All the riser does is take all of the PCIe pins including power, pass them through a flat cable and terminates them into another connector you plug the GPU into. As long as the GPU can tolerate the additional I*R voltage loss across the cable, it should be fine. Only way to find out for sure is to try it.
If the riser is well-made, the PCIe slot can be extended by a somewhat ridiculous amount. LTT tried it for fun a year or so ago and they put the GPU something like 10' away from the PC before it quit working.
