Does this Power Supply have standard dimensions?
salerhino
1,263
Hello Tom's hardware community!
I am planning to transfer my old system in new case, but I have 1 problem.
I don't know if my old PSU will fit in new case.
I have HP dc7800 convertible minitower PC (it is actually mid-tower), picture: http://3.bp.blogspot.com/-5Asec96mXso/U1FjdwmRDtI/AAAAAAAAAtQ/JZbKu3wW1ao/s1600/1.jpg (1st from left).
And my power supply is:https://www.amazon.com/HP-DC7900-460968-001-462434-001-DPS-365BB/dp/B00QE5OTIE
And I am planning to buy this case:https://shop.benchmark.rs/racunari_i_komponente/kucista/ms_industrial_midi_tower_knight-72295?utm_source=eponuda.com&utm_medium=eponuda&utm_campaign=direct_link
I know that both cases support ATX size of mobo, but i'm still unsure will my old PSU fit in new case?
Please reply, as soon as possible!
Thanks in advance !
Even if it is on the right side, motherboard will be standard. If it in the right side, the motherboard will be upside down. So if you install it on the right side, it will be in the correct orientation. Motherboard screw holes are standard (if it is not something like msi vortex or laptop).
Well, thanks anyway, but it seems hat everything related with this computer will be forgotten...
I guess you didn't pay attention, like I didn't, that the stupid motherboard is on the left side instead of right, and that PC is opening on the right...
So it seems I will have to buy whole new PC...
What do you mean?
You can't remove the motherboard?
Damn that sucks.
If you ever want to build a gaming PC, let me know and I can put together a list for you using local parts. :)
Nah, I can remove mother board, but it is on the left side of case, like this: http://prntscr.com/bymutv (instead of removing left side of case, i am removing right side);
Case is not BTX , it seems that is inverted or upside-down ATX how people named it...
But it is on the left, not right, how can I install mother board which is on this side http://prntscr.com/byn3m6
in case like this where I have to open that side? https://shop.benchmark.rs/racunari_i_komponente/kucista/ms_industrial_midi_tower_knight-72295?utm_source=eponuda.com&utm_medium=eponuda&utm_campaign=direct_link
