[SOLVED] Does this PSU have PFC? Will PFC affect my power bill?
Lack of a voltage switch doesn't always mean a PSU has APFC or any form of PFC at all. If a power supply has a fixed input voltage, say a 230v only PSU, it will not have a voltage switch regardless of the presence of PFC. I cannot find information to see the input voltage range of the PSU, or information on whether it has PFC.
Regardless, PFC does not effect your power bill in 99% of cases as consumers are billed real power. It does cause increased stress on power grid etc, but this doesn't really effect your power bill.
What does effect your power bill is efficiency. It does not have any 80+ certification and I doubt it is very efficient, which WILL have an effect on your power bill. A lack of 80+ COULD be a result of no active PFC...
It's a low efficiency garbage psu that affect everything you connect it to.
Another way of determining if the PSU has Active PFC is to look for the absence of the little red AC input voltage selector switch. The absence of that little switch indicates that it has automatic input voltage detection and selection and Active PFC.
The PSU has no voltage switch, so it has Active PFC?
Well, if you use a power supply like this, there's a good chance your PC will be using zero watts very shortly. Which I guess can be looked at as a deal in a certain light.
What do you mean by 0 watts? Shut off?
Also, an EVGA 400w PSU has no power switch on the back and does have a voltage switch. If the $31 PSU has PFC, then by buying the EVGA 400w, I'm sacrificing PFC.
What does effect your power bill is efficiency. It does not have any 80+ certification and I doubt it is very efficient, which WILL have an effect on your power bill. A lack of 80+ COULD be a result of no active PFC; Active PFC is required to pass 80+ Certification. However, a lack of 80+ could be a result of many other things, so that does not immediately mean this PSU lacks active PFC.
Also as said above, a PSU of unknown quality and unknown brand without any information is a very bad idea. It could fail and kill parts of your computer.
Novice here, but I believe the information presented above is correct.
There are 2 versions of the EVGA N1 400w, one made by HEC and one made by another OEM I cannot remember. The HEC model has a voltage switch at the rear and the other model does not have a voltage switch.
NEITHER have active PFC.
The latter version of the EVGA N1 400w manages full range input and no voltage switch by having voltage detection circuitry and a relay which essentially flips the voltage selector automatically. However, it does NOT have active power factor correction.
I hear online that PSUs that have no power switch on the back are extremely low quality.
