Question Does upgrading to a higher resolution monitor lower fps? How much i'll lose?
Apr 1, 2020
Will I get lower fps when I upgrade from 1360x720 to 2560x1080? I do not fully understand this stuff. How much i'll lose? Is there a way to calc that?
My specs are Pentium G5400, GTX 1050 Ti (4gb) and 8GB Ram.
Apr 1, 2020
In general...all things being equal...when you up the resolution you lower the fps.
I'd guess you might lose about half.
Wtf, half of my FPS? So If I have 100 FPS now, will cut it for 50? So its not a worth trade, right?
Can't really say how much as it depends on many factors and game to game but it will be significant.
Do you think it can be the half too? I was thinking in something about 15%.
1360 × 768 = 1,044,480 pixels
2560 × 1080 = 2,764,800 pixels
2.7× as many pixels means you'll get around 1/2.7× as many frames, or 38% of what you had before. That is assuming your are entirely limited by graphics card power. The loss will be less if you are limited by CPU power even at the lower resolution.
Reactions: Reidrigo
