H hlindsay06 Commendable Mar 20, 2016 1 0 1,510 Mar 20, 2016 #1 Building a low budget gaming computer, and was just wondering if these two parts were compatible, and if not which case of similar pricing I could use instead. Thanks in advance.
Solution O O Oishlam Mar 20, 2016 Of course! The case's maximum GPU length is 420mm, while the longest Zotac GT 720 card is a mere 145mm! Surely enough room. Good luck! -Oishlam
O Oishlam Reputable Nov 8, 2015 58 0 4,640 Mar 20, 2016 Solution #2 Of course! The case's maximum GPU length is 420mm, while the longest Zotac GT 720 card is a mere 145mm! Surely enough room. Good luck! -Oishlam Upvote 0 Downvote Solution
