Dolby Atmos for Headphones Works in CU. (Kinda)
Clovis559
28
Thing about Dolby Atmos, far as I know, other than the need for a compatible, ideal 5.1.2/5.2.2 receiver, quality source, etc... It takes a speaker system configured correctly with am appreciable amount of loudness to fully enjoy the benefits of this 3d audio experience. While I've never had an opportunity to listen to Atmos on speakers or headphones, I was under the impression headphones can only emulate vs a speaker setup. If not, what headphones might you recommend that'd be ideal for Dolby Atmos or Dolby in general? I'd have thought ultrasone phones might be ideal, though I really don't buy into their s-logic tech, while some claim it makes a real difference. What's your opinion on an ideal headphone for Dolby Atmos?
Clovis559
28
The only like "Atmos for Headphones" I've heard is Overwatch. So for gaming I like crisp sounds, low bass, I like Seinnheiser.
In theory Atmos should work with any headphone. Seinnheiser has headphones for most price points from $30-$1600, you can fit your budget accordingly.
