Dos won't work correctly
fromalk
5
Hello,
normally I always used a intel processor with my 32bit windows, now scince a week or 2 I've upgraded to an amd x2 4800+ still using a windows xp sp2 32bit version scince benchmarks show that this one is still faster...
No when I experianced somenetwork trouble I tried to ping an ip adress and a domain name, both resolving in a strange error:
http://www.fromalk.be/screenies/Untitled-1.jpg
This is a problem scince I just notiec that some programs like sSiSoftware try to run dos command resolving in this kind of error
Any suggestions?
One thing you might want to try is turning off the Windows firewall that comes with SP2. It may sometimes block certain programs on your computer from getting on the internet. With the problem you are having with pinging, I am not sure what to tell you.
