Question Double checking Heat Sink specs compatibility with i7 LGA 1200
luckyniji13
58
I have 10th Gen Core i7 LGA 1200 and a heat sink: Thermaltake Engine 27 1U Low-Profile 70W Intel 60mm Low Noise PWM Fan Forty Fan Blade CPU Cooler CL-P032-CA06SL-A
NewEgg advertised this heatsink as being compatible with the LGA 1200 socket but on the box of the item itself, it doesn't list that it is compatible with a 1200. Here is the product's page: https://www.neweggbusiness.com/product/product.aspx?item=9b-35-106-417
What say you?
Yes, lga1200 has the same cooling specs as lga1151.
You are ok there.
What model of processor do you have?
Non K processors should come with a stock intel cooler that is likely a better performer than the cooler you listed.
