double post sorry
rapsney
9
I am having HUGE issues with my pc. I am having game crashes, temps that range from 30c to 65c just idle, and blue screen mem dumps in xp. I have tried all i know to do which include, new mobo, re doing thermal pasting, new heatsink, and new mem. I have even tried clean format of xp with no avail. Please help as i can barley do anything at this time.
System Information
Time of this report: 6/5/2006, 15:50:52
Machine name: MIKE-IS7IIWZT8S
Operating System: Windows XP Home Edition (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: BIOS Date: 10/31/05 09:57:24 Ver: 08.00.12
Processor: Intel(R) Pentium(R) 4 CPU 3.00GHz (2 CPUs)
Memory: 1024MB RAM
Page File: 269MB used, 2193MB available
Windows Dir: C:WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce 6600 GT
Manufacturer: NVIDIA
Chip type: GeForce 6600 GT
DAC type: Integrated RAMDAC
Device Key: EnumPCIVEN_10DE&DEV_00F1&SUBSYS_21191682&REV_A2
Display Memory: 128.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: ViewSonic VA712b
Monitor Max Res: 1280,1024
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.8421 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 3/9/2006 15:29:00, 3968512 bytes
WHQL Logo'd: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 3/9/2006 15:29:00, 3650368 bytes
Device Identifier: {D7B71E3E-43B1-11CF-D755-130103C2CB35}
Vendor ID: 0x10DE
Device ID: 0x00F1
SubSys ID: 0x21191682
Revision ID: 0x00A2
Revision ID: 0x00A2
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not run
Sound Devices
Description: SB Audigy 2 ZS Audio [E000]
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: PCIVEN_1102&DEV_0004&SUBSYS_20021102&REV_04
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: ctaud2k.sys
Driver Version: 5.12.0001.0442 (English)
WHQL Logo'd: Yes
Date and Size: 11/18/2003 21:13:54, 366160 bytes
Other Files:
Driver Provider: Creative
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 4000, 192000
Static/Strm HW Mix Bufs: 64, 62
Static/Strm HW 3D Bufs: 64, 62
HW Memory: 0
Voice Management: Yes
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run
Sound Capture Devices
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF
DirectMusic
DLS Path: C:WINDOWSSYSTEM32driversGM.DLS
DLS Version: 1.00.0016.0002
Acceleration: Enabled
Ports: SB Audigy 2 ZS DirectMusic Synthesizer [E000], Hardware (Kernel Mode), Output, DLS, Internal, Default Port
SB Audigy 2 ZS Audio [E000], Software (Kernel Mode), Output, DLS, Internal
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS Synth A [E000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS Sw Synth [E000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS Synth B [E000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS MIDI IO [E000] [Emulated], Hardware (Not Kernel Mode), Output, No DLS, External
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
SB Audigy 2 ZS MIDI IO [E000] [Emulated], Hardware (Not Kernel Mode), Input, No DLS, External
Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal
Registry: OK
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: USB Receiver
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC513
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
Registry: OK
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x1106, 0x3038
| Matching Device ID: usbroot_hub
| Lower Filters: vulfntrs
| Service: usbhub
| Driver: usbhub.sys, 8/4/2004 01:08:42, 57600 bytes
| Driver: usbd.sys, 8/23/2001 07:00:00, 4736 bytes
Gameport Devices
+ PCI bus
| Matching Device ID: *pnp0a03
| Service: pci
| Driver: pci.sys, 8/4/2004 01:07:46, 68224 bytes
+-+ Creative Game Port
| | Matching Device ID: pciven_1102&dev_7003&subsys_00401102
| | Service: gameenum
| | Driver: gameenum.sys, 8/4/2004 01:08:21, 10624 bytes
PS/2 Devices
+ Logitech HID-Compliant Keyboard
| Matching Device ID: hidvid_046d&pid_c513&mi_00
| Service: kbdhid
| Driver: kbdhid.sys, 8/4/2004 00:58:34, 14848 bytes
| Driver: kbdclass.sys, 8/4/2004 00:58:32, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: rootrdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 03:01:07, 40840 bytes
+ Logitech HID-compliant Cordless Mouse
| Matching Device ID: hidvid_046d&pid_c513&mi_01&col01
| Upper Filters: LMouKE
| Lower Filters: LHidKE
| Service: mouhid
| Driver: mouhid.sys, 8/17/2001 13:48:00, 12160 bytes
| Driver: mouclass.sys, 8/4/2004 00:58:32, 23040 bytes
| Driver: LHidKE.Sys, 3/28/2006 17:56:06, 27008 bytes
| Driver: LMouKE.Sys, 3/28/2006 17:55:58, 69760 bytes
| Driver: KHALMNPR.Exe, 3/28/2006 17:38:32, 94208 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: rootrdp_mou
| Upper Filters: mouclass
| Service: TermDD
DirectPlay Service Providers
DirectPlay8 Modem Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider - Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay - Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay - Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM2
DirectPlay8 TCP/IP Service Provider: Local Area Connection - IPv4 -
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 34.3 GB
Total Space: 76.3 GB
File System: NTFS
Model: ST380013A
Drive: D:
Model: LITE-ON DVDRW SOHW-1693S
Driver: c:windowssystem32driverscdrom.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:52, 49536 bytes
Drive: E:
Model: LITE-ON LTR-48126S
System Devices
Name: Intel(R) PRO/1000 MT Network Connection
Device ID: PCIVEN_8086&DEV_100E&SUBSYS_80EE1043&REV_023&267A616A&0&68
Driver: n/a
Name: VIA CPU to AGP2.0/AGP3.0 Controller
Device ID: PCIVEN_1106&DEV_B198&SUBSYS_00000000&REV_003&267A616A&0&08
Driver: C:WINDOWSsystem32DRIVERSVIAAGP1.SYS, 5.01.0000.3442 (English), 7/2/2003 07:42:00, 27904 bytes
Name: VIA Standard Host Bridge
Device ID: PCIVEN_1106&DEV_7308&SUBSYS_00000000&REV_003&267A616A&0&07
Driver: n/a
Name: VIA I/O APIC Interrupt Controller
Device ID: PCIVEN_1106&DEV_5308&SUBSYS_81991043&REV_003&267A616A&0&05
Driver: n/a
Device ID: PCIVEN_1106&DEV_4308&SUBSYS_00000000&REV_003&267A616A&0&04
Driver: n/a
Name: VIA Standard PCI to ISA Bridge
Device ID: PCIVEN_1106&DEV_3227&SUBSYS_00000000&REV_003&267A616A&0&88
Driver: C:WINDOWSsystem32DRIVERSisapnp.sys, 5.01.2600.0000 (English), 8/17/2001 13:58:02, 35840 bytes
Device ID: PCIVEN_1106&DEV_3208&SUBSYS_00000000&REV_003&267A616A&0&03
Driver: n/a
Name: VIA SATA RAID Controller
Device ID: PCIVEN_1106&DEV_3149&SUBSYS_80E91043&REV_803&267A616A&0&78
Driver: C:WINDOWSsystem32DRIVERSviamraid.sys, 5.01.2600.0430 (English), 4/26/2005 14:22:40, 60928 bytes
Name: VIA USB Enhanced Host Controller
Device ID: PCIVEN_1106&DEV_3104&SUBSYS_31041106&REV_863&267A616A&0&84
Driver: C:WINDOWSsystem32driversusbehci.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:37, 26624 bytes
Driver: C:WINDOWSsystem32driversusbport.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:42, 142976 bytes
Driver: C:WINDOWSsystem32usbui.dll, 5.01.2600.2180 (English), 8/4/2004 02:56:46, 74240 bytes
Driver: C:WINDOWSsystem32driversusbhub.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:42, 57600 bytes
Driver: C:WINDOWSsystem32hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 02:56:42, 7168 bytes
Name: VIA Rev 5 or later USB Universal Host Controller
Device ID: PCIVEN_1106&DEV_3038&SUBSYS_30381106&REV_813&267A616A&0&83
Driver: C:WINDOWSsystem32driversusbuhci.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:37, 20480 bytes
Device ID: PCIVEN_1106&DEV_3038&SUBSYS_30381106&REV_813&267A616A&0&82
Device ID: PCIVEN_1106&DEV_3038&SUBSYS_30381106&REV_813&267A616A&0&81
Device ID: PCIVEN_1106&DEV_3038&SUBSYS_30381106&REV_813&267A616A&0&80
Device ID: PCIVEN_1106&DEV_2308&SUBSYS_00000000&REV_003&267A616A&0&02
Driver: n/a
Device ID: PCIVEN_1106&DEV_1308&SUBSYS_00000000&REV_003&267A616A&0&01
Driver: n/a
Name: VIA Bus Master IDE Controller
Device ID: PCIVEN_1106&DEV_0571&SUBSYS_80E91043&REV_063&267A616A&0&79
Driver: C:WINDOWSsystem32DRIVERSviaide.sys, 1.00.0001.0001 (English), 8/4/2004 00:59:42, 5376 bytes
Driver: C:WINDOWSsystem32DRIVERSpciidex.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:41, 25088 bytes
Driver: C:WINDOWSsystem32DRIVERSatapi.sys, 5.01.2600.2180 (English), 8/4/2004 00:59:42, 95360 bytes
Device ID: PCIVEN_1106&DEV_0308&SUBSYS_00000000&REV_003&267A616A&0&00
Driver: n/a
Name: Creative Game Port
Device ID: PCIVEN_1102&DEV_7003&SUBSYS_00401102&REV_043&267A616A&0&49
Driver: C:WINDOWSsystem32driversgameenum.sys, 5.01.2600.2180 (English), 8/4/2004 01:08:21, 10624 bytes
Name: OHCI Compliant IEEE 1394 Host Controller
Device ID: PCIVEN_1102&DEV_4001&SUBSYS_00101102&REV_043&267A616A&0&4A
Driver: C:WINDOWSsystem32DRIVERSohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 01:10:08, 61056 bytes
Driver: C:WINDOWSsystem32DRIVERS1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 01:10:06, 53248 bytes
Driver: C:WINDOWSsystem32DRIVERSnic1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:58:29, 61824 bytes
Driver: C:WINDOWSsystem32DRIVERSarp1394.sys, 5.01.2600.2180 (English), 8/4/2004 00:58:29, 60800 bytes
Driver: C:WINDOWSsystem32DRIVERSenum1394.sys, 5.01.2600.0000 (English), 8/17/2001 08:46:40, 6400 bytes
Name: Creative SB Audigy 2 ZS (WDM)
Device ID: PCIVEN_1102&DEV_0004&SUBSYS_20021102&REV_043&267A616A&0&48
Driver: C:WINDOWSsystem32ksuser.dll, 5.03.2600.2180 (English), 8/4/2004 02:56:42, 4096 bytes
Driver: C:WINDOWSsystem32ksproxy.ax, 5.03.2600.2180 (English), 8/4/2004 02:56:57, 130048 bytes
Driver: C:WINDOWSsystem32driversks.sys, 5.03.2600.2180 (English), 8/4/2004 01:15:21, 140928 bytes
Driver: C:WINDOWSsystem32driversdrmk.sys, 5.01.2600.2180 (English), 8/4/2004 01:07:58, 60288 bytes
Driver: C:WINDOWSsystem32driversportcls.sys, 5.01.2600.2180 (English), 8/4/2004 01:15:49, 145792 bytes
Driver: C:WINDOWSsystem32driversstream.sys, 5.03.2600.2180 (English), 8/4/2004 01:08:02, 48640 bytes
Driver: C:WINDOWSsystem32wdmaud.drv, 5.01.2600.2180 (English), 8/4/2004 02:56:57, 23552 bytes
Driver: C:WINDOWSsystem32driversctac32k.sys, 5.12.0001.0443 (English), 11/5/2003 01:26:02, 645392 bytes
Driver: C:WINDOWSsystem32driversctaud2k.sys, 5.12.0001.0442 (English), 11/18/2003 21:13:54, 366160 bytes
Driver: C:WINDOWSsystem32driversctoss2k.sys, 5.12.0001.0441 (English), 10/7/2003 21:06:50, 178672 bytes
Driver: C:WINDOWSsystem32driversctprxy2k.sys, 5.12.0001.0441 (English), 10/7/2003 21:08:12, 6096 bytes
Driver: C:WINDOWSsystem32driversctsfm2k.sys, 5.12.0001.0441 (English), 10/7/2003 21:09:10, 130288 bytes
Driver: C:WINDOWSsystem32driversemupia2k.sys, 5.12.0001.0442 (English), 10/13/2003 04:42:12, 145488 bytes
Driver: C:WINDOWSsystem32driversha10kx2k.sys, 5.12.0001.0444 (English), 10/21/2003 04:26:08, 904496 bytes
Driver: C:WINDOWSsystem32drivershaP16v2k.sys, 5.12.0001.0442 (English), 10/21/2003 04:23:44, 148432 bytes
Driver: C:WINDOWSsystem32driverspfmodnt.sys, 3.00.0000.0003 (English), 3/5/2003 12:19:28, 15840 bytes
Driver: C:WINDOWSsystem32ctdlang.dat, 10/21/2003 04:54:50, 217272 bytes
Driver: C:WINDOWSsystem32ctstatic.dat, 10/21/2003 04:47:40, 298971 bytes
Driver: C:WINDOWSsystem32ctdaught.dat, 10/21/2003 04:47:34, 53932 bytes
Driver: C:WINDOWSsystem32a3d.dll, 80.00.0000.0003 (English), 10/6/2003 01:38:06, 65536 bytes
Driver: C:WINDOWSsystem32commonfx.dll, 5.12.0001.0440 (English), 10/6/2003 01:44:28, 114688 bytes
Driver: C:WINDOWSsystem32ctaudfx.dll, 5.12.0001.0441 (English), 11/18/2003 02:23:50, 585728 bytes
Driver: C:WINDOWSsystem32ctsblfx.dll, 5.12.0001.0440 (English), 10/6/2003 01:46:14, 606208 bytes
Driver: C:WINDOWSsystem32sfman32.dll, 5.12.0001.0130 (English), 8/17/2001 01:35:46, 36864 bytes
Driver: C:WINDOWSsystem32ctbas2w.dat, 10/21/2003 04:54:48, 140643 bytes
Driver: C:WINDOWSsystem32ctsbas2w.dat, 10/21/2003 04:54:42, 264466 bytes
Driver: C:WINDOWSsystem32SBAudigy.ico, 8/16/2001 23:42:28, 7406 bytes
Driver: C:WINDOWSsystem32Audigy.bmp, 11/12/2001 20:48:20, 1912 bytes
Driver: C:WINDOWSsystem32ctcoinst.dll, 3.00.0000.0004 (English), 10/6/2003 01:48:30, 69632 bytes
Driver: C:WINDOWSsystem32ctdvinst.dll, 0.00.0000.0008 (English), 10/6/2003 01:48:42, 143360 bytes
Driver: C:WINDOWSsystem32driversctdvda2k.sys, 5.13.0001.0413 (English), 10/13/2003 22:17:56, 332800 bytes
Name: NVIDIA GeForce 6600 GT
Device ID: PCIVEN_10DE&DEV_00F1&SUBSYS_21191682&REV_A24&354AEA31&0&0008
Driver: C:WINDOWSsystem32DRIVERSnv4_mini.sys, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 3650368 bytes
Driver: C:WINDOWSsystem32nv4_disp.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 3968512 bytes
Driver: C:WINDOWSsystem32nvsvc32.exe, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 143436 bytes
Driver: C:WINDOWSsystem32nvhwvid.dll, 6.14.0010.8421 (), 3/9/2006 15:29:00, 573440 bytes
Driver: C:WINDOWSsystem32nvapi.dll, 6.14.0010.8421 (), 3/9/2006 15:29:00, 98304 bytes
Driver: C:WINDOWSsystem32nvoglnt.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 5419008 bytes
Driver: C:WINDOWSsystem32nvcpl.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 7561216 bytes
Driver: C:WINDOWSsystem32nvmctray.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 86016 bytes
Driver: C:WINDOWSsystem32nvwddi.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 81920 bytes
Driver: C:WINDOWSsystem32nvnt4cpl.dll, 6.14.0010.11026 (English), 3/9/2006 15:29:00, 286720 bytes
Driver: C:WINDOWSsystem32nvmccs.dll, 6.14.0010.8421 (English), 3/9/2006 15:29:00, 229376 bytes
Driver: C:WINDOWShelpnvcpl.hlp, 3/9/2006 15:29:00, 171072 bytes
Driver: C:WINDOWShelpnvwcplen.hlp, 3/9/2006 15:29:00, 55444 bytes
Driver: C:WINDOWSsystem32nvcod.dll, 1.00.0000.0035 (English), 3/9/2006 15:29:00, 35840 bytes
Driver: C:WINDOWSsystem32nvcodins.dll, 1.00.0000.0035 (English), 3/9/2006 15:29:00, 35840 bytes
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:41 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:41 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:41 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:41 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:48 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:48 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:03 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:03 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:48 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/23/2001 07:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/23/2001 07:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 35328 bytes
gameenum.sys: 5.01.2600.2180 English Final Retail 8/4/2004 01:08:21 10624 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 82432 bytes
system.dll: 1.01.4322.2032 English Final Retail 5/22/2006 15:27:39 1224704 bytes
Microsoft.DirectX.Direct3D.dll: 9.05.0132.0000 English Final Retail 6/4/2006 19:51:00 473600 bytes
Microsoft.DirectX.Direct3DX.dll: 9.06.0168.0000 English Final Retail 6/4/2006 19:51:00 567296 bytes
Microsoft.DirectX.DirectDraw.dll: 5.04.0000.2904 English Final Retail 6/4/2006 19:51:01 145920 bytes
Microsoft.DirectX.DirectInput.dll: 5.04.0000.2904 English Final Retail 6/4/2006 19:51:02 159232 bytes
Microsoft.DirectX.DirectPlay.dll: 5.04.0000.2904 English Final Retail 6/4/2006 19:51:03 364544 bytes
Microsoft.DirectX.DirectSound.dll: 5.04.0000.2904 English Final Retail 6/4/2006 19:51:03 178176 bytes
Microsoft.DirectX.AudioVideoPlayback.dll: 5.04.0000.2904 English Final Retail 6/4/2006 19:50:57 53248 bytes
Microsoft.DirectX.Diagnostics.dll: 5.04.0000.2904 English Final Retail 6/4/2006 19:50:59 12800 bytes
Microsoft.DirectX.dll: 5.04.0000.2904 English Final Retail 6/4/2006 19:50:57 223232 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/23/2001 07:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 02:56:42 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 02:56:46 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:41 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:42 59904 bytes
dxmasf.dll: 6.04.0009.1125 English Final Retail 8/4/2004 02:56:42 498205 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:42 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:57 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:43 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 20480 bytes
qasf.dll: 10.00.0000.3802 English Final Retail 1/28/2005 13:44:28 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:24 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/29/2005 22:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3928 English Final Retail 8/4/2004 02:56:45 246302 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 02:56:57 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 02:56:57 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 02:56:42 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 02:56:42 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 02:56:42 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 02:56:42 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 02:56:42 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 02:56:57 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:15:21 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:42 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:08:02 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:58:38 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/4/2004 00:58:40 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:58:41 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:58:41 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/4/2004 00:58:38 5504 bytes
bdaplgin.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 18432 bytes
bdasup.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:12 11776 bytes
msdvbnp.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:57 56832 bytes
psisdecd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:44 363520 bytes
psisrndr.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:57 33280 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:57 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:12 10880 bytes
mpe.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:12 15360 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:12 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 02:56:43 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:16 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:28 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:16 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:44 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:57 90624 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:10:21 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 02:56:46 50688 bytes
msdv.sys: 5.03.2600.2180 English Final Retail 8/4/2004 01:09:58 51328 bytes
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Creative LiveRecording Filter,0x00400000,0,1,LiveRec.ax,2.00.0001.0000
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
Nero Scene Detector 2,0x00200000,2,0,NeSceneDetector.ax,4.02.0000.0027
Creative Wave Writer,0x00200000,1,0,WavWrite.ax,2.00.0001.0000
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00600000,1,1,NeAudio.ax,4.02.0000.0027
Creative MLP Source Filter,0x00400000,0,1,MlpSrc.ax,1.01.0001.0000
DV Scenes,0x00200000,1,1,NVDV.dll,3.00.0002.0001
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3802
Creative NVF Filter,0x00400000,0,1,NvfSrc.ax,1.00.0006.0000
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
BPM Metadata,0x001fffff,1,1,MetaBPM.ax,1.00.0003.0000
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Compression Filter,0x00200000,1,1,ir50_32.dll,5.2562.0015.0055
Windows Media Audio Decoder,0x00800001,1,1,msadds32.ax,8.00.0000.4487
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
CT Null Render Filter,0x00200000,1,0,NullRndr.ax,1.00.0001.0000
WMT Format Conversion,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
CT Time-Scaling filter,0x00100000,1,1,TimeScal.ax,2.00.0000.0001
StreamBufferSink,0x00200000,0,0,sbe.dll,
WMT Black Frame Generator,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Resize,0x00200000,1,1,NeResize.ax,4.02.0000.0027
MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Indeo® video 5.10 Decompression Filter,0x00640000,1,1,ir50_32.dll,5.2562.0015.0055
WMT Screen Capture filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
SVM Metadata,0x001fffff,1,1,MetaSVM.ax,1.00.0006.0000
Microsoft Screen Video Decompressor,0x00800000,1,1,msscds32.ax,8.00.0000.4487
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.05.2600.2749
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3 Decoder,0x00810000,1,1,l3codecx.ax,1.05.0000.0050
Nero Audio Stream Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.05.2600.2180
ACELP.net Sipro Lab Audio Decoder,0x00800001,1,1,acelpdec.ax,1.04.0000.0000
Nero Digital AVC Audio Encoder,0x00200000,1,2,NeNDAud.ax,4.02.0000.0027
Nero Digital AVC File Writer,0x00200000,1,0,NeNDMux.ax,4.02.0000.0027
Nero Digital AVC Null Renderer,0x00200000,1,0,NeNDMux.ax,4.02.0000.0027
Nero Digital AVC Muxer,0x00200000,2,1,NeNDMux.ax,4.02.0000.0027
Nero Digital AVC Video Enc,0x00200000,1,2,,
WMS Filter,0x00400000,0,1,CTWMSFLT.DLL,1.12.0001.0000
Nero QuickTime(tm) Video Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0000.0027
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.05.2600.2749
File Source (Netshow URL),0x00400000,0,1,wmpasf.dll,10.00.0000.3646
Nero Digital AVC Subpicture Enc,0x00200000,1,0,NeNDMux.ax,4.02.0000.0027
Nero Format Converter,0x00200000,1,1,NeroFormatConv.ax,4.02.0000.0027
WMT Import Filter,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
DV Splitter,0x00600000,1,2,qdv.dll,6.05.2600.2180
Bitmap Generate,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Video Decoder,0x00800000,1,1,wmvds32.ax,8.00.0000.4487
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,
Windows Media Video Decoder,0x00800000,1,1,wmv8ds32.ax,8.00.0000.4000
Nero Photo Source,0x00200000,0,1,NePhotoSource.ax,4.02.0000.0027
WMT VIH2 Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
PCM to EXT,0x00200000,0,0,Pcm2Ext.ax,5.00.0000.0000
Nero Video Analyzer,0x00200000,2,0,NeVideoAnalyzer.ax,4.02.0000.0027
Record Queue,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero ES Video Reader,0x00600000,0,1,NDParser.ax,4.02.0000.0027
CT Karaoke filter,0x00100000,1,1,Karaoke.ax,2.00.0000.0001
DV Source Filter,0x00400000,0,1,NVDV.dll,3.00.0002.0001
Nero Audio CD Filter,0x00200000,0,1,NeAudCD.ax,4.02.0000.0027
Creative MP3 Source Filter,0x00400000,0,1,Mp3Src.ax,2.00.0003.0000
Windows Media Multiplexer,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASX v.2 file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
NSC file Parser,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ACM Wrapper,0x00600000,1,1,quartz.dll,6.05.2600.2749
Windows Media source filter,0x00600000,0,2,wmpasf.dll,10.00.0000.3646
Video Renderer,0x00800001,1,0,quartz.dll,6.05.2600.2749
Frame Eater,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero DVD Navigator,0x00600000,0,4,NeDVD.ax,4.02.0000.0027
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,
Line 21 Decoder,0x00600000,1,1,qdvd.dll,6.05.2600.2180
Video Port Manager,0x00600000,2,1,quartz.dll,6.05.2600.2749
WST Decoder,0x00600000,1,1,wstdecod.dll,5.03.2600.2180
Video Renderer,0x00400000,1,0,quartz.dll,6.05.2600.2749
Nero Audio Sample Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
Nero Vcd Navigator,0x00600000,0,2,NeVCD.ax,4.02.0000.0027
DivX Decoder Filter,0xff800000,1,1,divxdec.ax,6.02.0000.0008
Creative AC3 Source Filter,0x00400000,0,1,AC3Src.ax,1.01.0000.0000
Nero Audio Processor,0x00200000,1,1,NeAudioConv.ax,4.02.0000.0027
CT SmartVolumeManagement filter,0x00100000,1,1,DSCompr.ax,1.00.0000.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,10.00.0000.3802
WMT Sample Information Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Mpeg2 Encoder,0x00200000,2,1,NeVCR.ax,4.02.0000.0027
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,5.03.2600.2180
Creative MP3 Writer,0x00200000,1,0,MP3Write.ax,1.02.0001.0000
Microsoft MPEG-4 Video Decompressor,0x00800000,1,1,mpg4ds32.ax,8.00.0000.4487
Nero Video Stream Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
DivX Demux,0x00600000,1,0,DivXMedia.ax,0.00.0000.0028
File writer,0x00200000,1,0,qcap.dll,6.05.2600.2180
Nero PS Muxer,0x00200000,1,1,NePSMuxer.ax,4.02.0000.0027
WMT Log Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Virtual Renderer,0x00200000,1,0,wmm2filt.dll,2.01.4026.0000
DVD Navigator,0x00200000,0,2,qdvd.dll,6.05.2600.2180
Overlay Mixer2,0x00400000,1,1,qdvd.dll,6.05.2600.2180
Nero Splitter,0x00600000,1,3,NeSplitter.ax,4.02.0000.0027
AVI Draw,0x00600064,9,1,quartz.dll,6.05.2600.2749
.RAM file Parser,0x00600000,1,0,wmpasf.dll,10.00.0000.3646
Nero File Source / Splitter,0x00600000,0,3,NeFSource.ax,4.02.0000.0027
WMT DirectX Transform Wrapper,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
G.711 Codec,0x00200000,1,1,g711codc.ax,5.01.2600.0000
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.05.2600.2180
DV Video Decoder,0x00800000,1,1,qdv.dll,6.05.2600.2180
Creative MP3 Source Filter,0x00400000,0,1,CTMP3SFT.DLL,1.00.0010.0000
Indeo® audio software,0x00500000,1,1,iac25_32.ax,2.00.0005.0053
Windows Media Update Filter,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Noise Reduction,0x00100000,1,1,NoisRedu.ax,3.00.0000.0002
ASF DIB Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ACM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF ICM Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF URL Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF JPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF DJPEG Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
ASF embedded stuff Handler,0x00600000,1,1,wmpasf.dll,10.00.0000.3646
DivX Subtitle Decoder,0x00600000,1,1,DivXMedia.ax,0.00.0000.0028
9x8Resize,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WIA Stream Snapshot Filter,0x00200000,1,1,wiasf.ax,1.00.0000.0000
Nero Video Processor,0x00200000,1,1,NeroVideoProc.ax,4.02.0000.0027
Nero Video Decoder,0x00600000,2,2,NeVideo.ax,4.02.0000.0027
Allocator Fix,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
SampleGrabber,0x00200000,1,1,qedit.dll,6.05.2600.2180
Null Renderer,0x00200000,1,0,qedit.dll,6.05.2600.2180
Creative WMA Writer,0x00200000,1,0,WMAWrite.ax,2.01.0001.0000
WMT Virtual Source,0x00200000,0,1,wmm2filt.dll,2.01.4026.0000
MPEG-2 Sections and Tables,0x005fffff,1,0,mpeg2data.ax,
IVF source filter,0x00600000,0,1,ivfsrc.ax,5.10.0002.0051
WMT Interlacer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Audio CD Navigator,0x00200000,0,1,NeAudCD.ax,4.02.0000.0027
StreamBufferSource,0x00200000,0,0,sbe.dll,
Smart Tee,0x00200000,1,2,qcap.dll,6.05.2600.2180
Creative WMA Source Filter,0x00400000,0,1,WmaSrc.ax,2.00.0004.0000
Overlay Mixer,0x00200000,0,0,qdvd.dll,6.05.2600.2180
Nero Scene Detector,0x00200000,1,0,NeSceneDetector.ax,4.02.0000.0027
AVI Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
Uncompressed Domain Shot Detection Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.05.2600.2749
QuickTime Movie Parser,0x00600000,1,1,quartz.dll,6.05.2600.2749
Wave Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
MIDI Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Multi-file Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
Lyric Parser,0x00400000,1,1,quartz.dll,6.05.2600.2749
File stream renderer,0x00400000,1,1,quartz.dll,6.05.2600.2749
XML Playlist,0x00400000,1,0,wmpasf.dll,10.00.0000.3646
Nero File Source,0x00200000,0,1,NeFileSrc.ax,4.02.0000.0027
Nero QuickTime(tm) Audio Decoder,0x00400000,1,1,NeQTDec.ax,4.02.0000.0027
Nero File Source (Async.),0x00400000,0,1,NeFileSourceAsync.ax,4.02.0000.0027
NVF Filter,0x00400000,0,1,CTNVFFLT.DLL,1.00.0000.0000
Nero DVD Decoder,0x00600000,2,2,NeVideo.ax,4.02.0000.0027
Nero Digital Parser,0x00600000,0,3,NDParser.ax,4.02.0000.0027
AVI Mux,0x00200000,1,0,qcap.dll,6.05.2600.2180
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.05.2600.2749
File Source (Async.),0x00400000,0,1,quartz.dll,6.05.2600.2749
File Source (URL),0x00400000,0,1,quartz.dll,6.05.2600.2749
WMT DV Extract,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Creative CDDA Source Filter,0x00400000,0,1,CDDA.ax,2.01.0001.0000
Nero Frame Capture,0x00200000,1,1,NeCapture.ax,4.02.0000.0027
WMT Switch Filter,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
WMT Volume,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Nero Video Sample Renderer,0x00200000,1,0,NeRender.ax,4.02.0000.0027
Stretch Video,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
Windows Media Pad VU Data Grabber,0x00600000,1,0,wmmfilt.dll,1.01.2427.0000
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.05.2600.2180
Nero DV Splitter,0x00200000,1,2,NeDVSplitter.ax,4.02.0000.0027
BDA MPEG2 Transport Information Filter,0x00200000,1,0,psisrndr.ax,6.05.2600.2180
QT Decompressor,0x00600000,1,1,quartz.dll,6.05.2600.2749
ShotBoundaryDet,0x00200000,1,1,wmmfilt.dll,1.01.2427.0000
MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.05.2600.2749
Indeo® video 4.4 Decompression Filter,0x00640000,1,1,ir41_32.ax,4.51.0016.0003
Indeo® video 4.4 Compression Filter,0x00200000,1,1,ir41_32.ax,4.51.0016.0003
WDM Streaming Data Transforms:
Microsoft Kernel Acoustic Echo Canceller,0x00000000,0,0,,
Microsoft Kernel GS Wavetable Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DLS Synthesizer,0x00200000,1,1,,5.03.2600.2180
Microsoft Kernel DRM Audio Descrambler,0x00200000,1,1,,5.03.2600.2180
Video Compressors:
WMVideo Encoder DMO,0x00600800,1,1,,
MSScreen encoder DMO,0x00600800,1,1,,
WMVideo9 Encoder DMO,0x00600800,1,1,,
WMVideo Advanced Encoder DMO,0x00600800,1,1,,
MSScreen 9 encoder DMO,0x00600800,1,1,,
DV Video Encoder,0x00200000,0,0,qdv.dll,6.05.2600.2180
Indeo® video 5.10 Compression Filter,0x00100000,1,1,ir50_32.dll,5.2562.0015.0055
MJPEG Compressor,0x00200000,0,0,quartz.dll,6.05.2600.2749
Nero Digital AVC Video Enc,0x00200000,1,2,NeNDVid.ax,4.02.0000.0027
Cinepak Codec by Radius,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.2.2 Codec (2 Logical CPUs),0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel 4:2:0 Video V2.50,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo(R) Video R3.2,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel Indeo® Video 4.5,0x00200000,1,1,qcap.dll,6.05.2600.2180
Indeo® video 5.10,0x00200000,1,1,qcap.dll,6.05.2600.2180
Intel IYUV codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.261 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft H.263 Video Codec,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft RLE,0x00200000,1,1,qcap.dll,6.05.2600.2180
Microsoft Video 1,0x00200000,1,1,qcap.dll,6.05.2600.2180
DivX® 6.2.2 YV12 Decoder,0x00200000,1,1,qcap.dll,6.05.2600.2180
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,,
WMAudio Encoder DMO,0x00600800,1,1,,
IAC2,0x00200000,1,1,quartz.dll,6.05.2600.2749
IMA ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.05.2600.2749
ACELP.net,0x00200000,1,1,quartz.dll,6.05.2600.2749
DSP Group TrueSpeech(TM),0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V1,0x00200000,1,1,quartz.dll,6.05.2600.2749
Windows Media Audio V2,0x00200000,1,1,quartz.dll,6.05.2600.2749
GSM 6.10,0x00200000,1,1,quartz.dll,6.05.2600.2749
Microsoft G.723.1,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT A-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
CCITT u-Law,0x00200000,1,1,quartz.dll,6.05.2600.2749
MPEG Layer-3,0x00200000,1,1,quartz.dll,6.05.2600.2749
Audio Capture Sources:
SB Audigy 2 ZS Audio [E000],0x00200000,0,0,qcap.dll,6.05.2600.2180
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Microsoft GS Wavetable SW Synth,0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS MIDI IO [E000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS Sw Synth [E000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS Synth A [E000],0x00200000,1,0,quartz.dll,6.05.2600.2749
SB Audigy 2 ZS Synth B [E000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming Capture Devices:
SB Audigy 2 ZS MIDI IO [E000],0x00200000,2,2,,5.03.2600.2180
SB Audigy 2 ZS Audio [E000],0x00200000,3,2,,5.03.2600.2180
WDM Streaming Rendering Devices:
SB Audigy 2 ZS DirectMusic Synthesizer [E000],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Sw Synth [E000],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Synth A [E000],0x00200000,1,1,,5.03.2600.2180
SB Audigy 2 ZS Synth B [E000],0x00200000,1,1,,5.03.2600.2180
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBC Network Provider,0x00200000,0,1,msdvbnp.ax,
Microsoft DVBS Network Provider,0x00200000,0,1,msdvbnp.ax,6.05.2600.2180
Microsoft DVBT Network Provider,0x00200000,0,1,msdvbnp.ax,
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,1,0,psisrndr.ax,6.05.2600.2180
MPEG-2 Sections and Tables,0x00600000,1,0,mpeg2data.ax,
WDM Streaming Mixer Devices:
Microsoft Kernel Wave Audio Mixer,0x00000000,0,0,,
BDA CP/CA Filters:
Decrypt/Tag,0x00600000,1,0,encdec.dll,
Encrypt/Tag,0x00200000,0,0,encdec.dll,
XDS Codec,0x00200000,0,0,encdec.dll,
Audio Renderers:
SB Audigy 2 ZS Audio [E000],0x00200000,1,0,quartz.dll,6.05.2600.2749
Default DirectSound Device,0x00800000,1,0,quartz.dll,6.05.2600.2749
Default WaveOut Device,0x00200000,1,0,quartz.dll,6.05.2600.2749
DirectSound: SB Audigy 2 ZS Audio [E000],0x00200000,1,0,quartz.dll,6.05.2600.2749
WDM Streaming System Devices:
SB Audigy 2 ZS Synth A [E000],0x00200000,11,2,,5.03.2600.2180
SB Audigy 2 ZS Audio [E000],0x00200000,13,2,,5.03.2600.2180
FIRST, MAKE YOUR POSTS SMALLER AS PEOPLE DO NOT WANT TO READ THROUGH THAT CRAP (ONLY IF WE ASK FOR SOME SPECIFIC PROBLEMS SHOULD YOU POST SOME, BUT NOT ALL)!
Did you put together your computer correctly? Double check that your brass standoffs are correctly placed and that your components are not grounding onto the case.
Also, what power supply are you using? If its a cheap, generic PSU, or underpowered, then many PC problems will occur.
Make sure your CPU is set to stock settings. Go into your BIOS (usually Del or F2) when your PC boots and check the FSB speed for your CPU.
Check RAM Timings as well. Look at the stock timings for your RAM and make sure they are right in the BIOS.
And next time, post your PC specs (like my sig) so that its easier to identify what you are using rather than try to decipher pages of crap.
I can safely say that this is the single longest post that I have ever seen :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy: :trophy:
