I have a pre-built system that I have been gaming on for quite some while now, that was finally ready for a gpu upgrade. I bought a gtx 1070, but wasn't smart enough to notice that it required a 8 pin connection, and my psu only provides dual 6 pin pci-e connections. BUT one of those 6 pin connections (the one that was attached to my previous gpu) has double the wires connected to it than it is supposed to. There are 6 yellow wires attached to the top of the connector, and 6 black ones to the bottom. Does that mean that this should be okay in delivering the correct amount of power to the gpu, and I could simply plug my 6 pin connector in to the 8 pin receptacle on the gpu?
I have a 500w psu, Allied AL-D500EXP
