Question Doubts about battery storage.
cloudff7ps1
457
What is the best long-term storage voltage for Li-Ion and Li-Po batteries? removable smartphone batteries i have chinese Nokia BP-5L and Xiaomi BM20 do you have any studies that prove the best voltage or voltage range for long term storage?
By "best long-term storage voltage" do you mean that the batteries are going to be installed in some device (charger ?) other than a smart phone and then stored in some manner?
More information needed.
Contact the manufacturers regarding long-term storage requirements.
For standard Lithium manganese oxide cells, anywhere between 30% (3.7v) and 50% (3.94v) is fine and 40% (3.82v) probably ideal. Given that the protection circuitry itself draws a small amount of current and if you ever want to use the battery it will be quicker to charge up, I expect for most people 50% would be better, but frequent checking at 40% should yield longest storage life--after 1 year 96% of the capacity should be retained, vs 80% if kept charged to 100% at 25°C
Li-ion batteries are only shipped at 30% for safety reasons, and this leads to a lot of old-stock products having the battery die in the unopened box from self-discharge. That's not just because draining below 2.5v is just as bad for longevity as charging above 4.3v, but because the protection circuits are often set to not allow charging a too-low Li-ion at all to prevent fires.
my BP-5L and BM20 batteries are not stored inside any device here in my city the temperature varies 33-35C for these conditions of mine what is the best long term storage voltage? Is there any official study on this?
what is the charging frequency and when the voltage drops what voltage is prompt to recharge
In the link I left for you it explains that at 40°C the permanent capacity loss is typically 15% after a year at 3.82v and 35% at 4.20v. I would suggest you keep your unused cells in the freezer because at 0°C there is only 2% permanent loss per year at 3.82v so it would take 11 years to drop to 80% capacity. Even fully charged to 4.20v there is only 6% loss per year at 0°C
There will be no undervoltage damage to the cells if you catch them before they drop below 3.0v and charge them back up to your desired storage voltage then. How long it takes to drain to there depends on your batteries. The internal self-discharge of Li-ion is pretty low under 4.0v but the protection circuits can cause a small but constant drain until they disconnect, usually ~2.5v.
I can't freeze I keep it in boxes but I need guidance on which voltage is best for long storage in my 33-35c conditions on these battery models I don't know if bm20 and bp-5l is lipo or liion
I didn't find studies
I have these batteries in reserve to use them in the future but I don't have a set time for when I'm going to use them so I want to preserve them as much as possible so in my conditions I need to find the best voltage to store them
I can't reduce these temperatures I don't use air conditioning very difficult for me to keep these batteries I live in a tropical region and the ambient temperature is this
but referring only to the voltage I showed 3.75v-3.8v are these voltages good for storage?
There's FAR more to this than just voltage. Your ambient temperatures will significantly shorten the life of any batteries. Your environment is not conducive to storage of batteries of any kind.
these batteries are hard to get because they are old and my device was designed only for these battery models my intention was to keep these in reserve
If you must store batteries long-term, then you need to be able to have as optimal conditions as possible for conserving those batteries. The basics of chemistry don't change based on what's convenient for you.
In a box, in a closet, away from any heat sources. But it's really a moot point as you'll most likely not be worried about those batteries in 3-5 years time, when the current batteries finally quit charging, as you'll most likely have a different phone by then in order to keep up with memory requirements, OS requirements, gimmicks, busted screens etc.
It's why most smart phones don't bother with user serviceable batteries any more, or make battery replacement semi-redundant, it's called planned obsolescence.
E-bay/ali is full of these batteries, it might be expensive for you due to shipping but they are not hard to find.
Local second hand shops,papers, flea markets, and so on will get you cheaper alternatives.
Also you only need the cases you already have, inside there is a charging circuit that you need to keep and a generic battery that you can change out for a new one.
(By you I mean a professional that knows what they are doing)
is there any small box sold on aliexpress to keep a temperature lower than room temperature and conserve batteries?
That's called an air conditioner.
(Edit: Or a refrigerator. Cooling things significantly below ambient requires a lot of power)
I'm sorry, but this whole plan is a very poorly thought-out one. Basically, you want magic to exist.
Now, you could spend thousands of dollars on ideal conditions for hoarding batteries for ancient technology, but in this case, it would be far cheaper to just buy a new phone every five years.
Reactions: Phillip Corcoran
