I have Corsair Triple Channel 6GB 1333MHz RAM
RAM SPEC
TR3X6G1333C9 6GB Kit 9-9-9-24 240pin 1.50v Ver8.1
6GB 3 x 2GB - 1333MHz DDR3-1333
This is my System Specs
When my PC starts it shows this "Memory Running at 1066MHz"
In Speccy and CPU-Z it shows Memory running at 539.7MHz
Why Is my memory not running at 1333MHz as it should?
Do I need to set it to 1333MHz myself by changing the settings in the BIOS
What seems to be the problem?
How do I fix this so my RAM works at its actual speed of 1333 MHz?
I haven't Overclocked the CPU, RAM or GPU.
RAM SPEC
http://www.corsair.com/memory/intel-memory-solutions/intel-triple-channel-kits/tr3x6g1333c9.html
