[SOLVED] DRAM Frequency too low(1866Mhz) compare with reality(3000Mhz).
Oct 30, 2020
My PC include:
  1. CPU: Ryzen 5 2600.
  2. Mainboard: B450M Pro4
  3. 4 slots ram: 2 KLEVV 4Gbs DDR4-3000 and 2 G.Skill 8Gbs DDR4-3000.
When I run CPU-z and DRAM Frequency is 931.1 MHz. Why is that? Would you please help me?
My PC include:
Have you enabled XMP? Also mix and match might hurt you here.
My PC include:
If you are running dual channel, then the chance is that it reads half the speed. It should be doubled, what does it say on task manager?
