I had a local shop replace my hard drive after it failed.
I installed XP and noticed that it was installing on "I:"
I ignored this and continued the build and installed all other S/W.
My PC runs OK but some S/W doesn't run properly and I have trouble installing some Apps. like Adobe Flash.
The repair shop says I have to reinstall XP and to unplug the multimedia card reader and any usb memory sticks before I start the install. They say this will cause the PC to re-map my hard drive as "C:" and the install will go OK. I only have one hard drive, and I also have a CD/DVD drive and a multimedia card reader.
My questions are:
- Do I really have to reinstall XP and other S/W?
- Is there any way of mapping my "I:" drive to be a "C:" drive without a reinstall?
- If I do have to reinstall XP, what do I need to do to map the hard drive as "C:"
My questions are:
